Results 1 to 10 of 13
Thread: brake light keeps coming on ????
    as above top right handside of dash layout in my golf i have the light for the park brake but then above that there is also a light that says brake on it and it keeps coming on any one know what that light is for
    Peregian Beach
    I'm going back a few years now but if I remember correctly it is a low fluid pessure light. Mine used to stuff up every couple of years. Try replacing the sender unit on the master cylinder or check it first by taking the wire off and seeing if it makes any difference.
    It's fluid a level light but also comes on with the handbrake too. Check the fluid level first.
    syncro Guest
    Golf 1s do not have a brake fluid level light.
    The light indicates a difference in pressure between the front and rear circuits. Either one of the brake light/pressure switches is defective or the master cylinder is defective.
    thanks to all i'll have a look at it this weekend with my dad
    cheers
    Dec 2006
    Kilsyth, VIC
    When I bought my Mk1 I was told that light has been on for years and no-one knew how to fix it...
    Mind you I picked the car up in Coffs Harbour and didn't notice it most of the way back to Sydney, so who knows if it goes on and off at will.
    To my point, after a service where all they did was oil, filters and wheel alignment/balance the light is off. The only sensor like thing that was replaced was the oil sensor which was leaking oil rather profusely.
    Is it wired up wrong, was it this other sensor that was the problem?
    Either way, it's off now.
    May 2006
    Adelaide South Australia
    Quote Originally Posted by syncro
    The late cars do. My car, built 9/80, has it. The top red light is res. level & the red light directly underneath is hand brake warning light. I have just fitted a new master cyl. today & the light was on during my test drive & went out going up our steep driveway. Adding more brake fluid solved the problem.
    syncro Guest
    Quote Originally Posted by jets
    That's because one of the circuits ran out of fluid. The brake fluid level indicators are a float that hangs off the cap with a plug on top.
    If yours was built 9/80 it must be a private import or do you mean complianced 9/80?
    May 2006
    Yes mine has a float hanging off the cap with a plug on top. I have just bought the car from the original owner & he most certainly would not have updated the system & the wiring is all original. He did say the car was one of the last sold in SA.
    Yes it is complianced 9/80. I don't know where to look for the build date.
    syncro Guest
    Gine me the VIN / Chassis number and I will see what I can find out.
Similar Threads
  1. Electrical problems with VW Golf V towbar
    By JandG in forum Mk5 Golf & Jetta
    Last Post: 08-03-2009, 08:50 PM
  2. Seatbelt Light
    By JayBee in forum Mk4 Golf & Bora and New Beetle
    Last Post: 27-02-2007, 07:05 PM
  3. Electric motor noise when opening and glove box light?
    By clone_tk422 in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 25-01-2007, 09:38 AM
  4. Brake reservoir lid
    By gman in forum Mk3 Golf & Vento
    Last Post: 14-01-2007, 01:05 PM
  5. Golf Mk1 brake confusion
    By tassie_euro_mk1 in forum Mk1 Golf
    Last Post: 21-07-2006, 05:47 PM
