Are you losing any brake fluid from the reseviour ?
Hello everyone, over the last few days occasionally when I'm slowing to a stop (such as pulling up at a mates house) the pedal loses all hardness and presses straight to the floor with minimal braking. As soon as I take my foot off the brake and apply it again the pedal is hard and usable again. It feels as if it loses all vacuum momentarily. How would I find out what's going on and will my brakes fail whilst I'm driving?
IG: jackie_melon
1993 MK1 CAB ! Work in Progress........
Yikes, you obviously need to sort this out ASAP
Loosing vacum makes the pedal go hard and won't let the pedal drop to the floor
I would suspect a fluid leak or maybe a mechanical problem where the pedal is disengaging from the master cyclinder somehow
Definately, you have a failed seal in the master cylinder.
You can still buy seal kits for them (not too hard to fix) or you can try to source another master cylinder, which you can also buy new from various places (Tooleys, GAP, etc).
Good luck!
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Thanks for the replies guys.
I'll keep my eye on the reservoir and let you know. As for fixing the seals, at the moment my budget is $0 as I'm having trouble finding any damn workand being my daily, I can't afford to have it off the road for too long....this suck ahah
IG: jackie_melon
Have a look for Peter Jones brake upgrade threads.
All the info you need to upgrade the booster and MC to a mk 3 item are there. A very worthy upgrade!
Living in a small country town with no public transport means my car is my only mode of transportation :/
Yeah I've heard about these Peter Jones threads, will look into it thanks![]()
IG: jackie_melon
