Results 1 to 5 of 5
Thread: Bottom End rebuild Advice
    May 2006
    Maroubra NSW
    Hi all,
    I'm rebuilding the bottom end of my diesel. I've got a new second hand crank which i've put the micrometer over and it measures well as standard.
    I'm just wondering, when i put the new standard bearings in, should i do that plastigage thing? it won't affect anything will it?
    Smithy
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
    Not that I build loads of engines. But if you are happy the crank measures as std, fit new bearings with plenty of oil on them and away you go.
    IMO I would still check the clearances with plastiguage on both the mains & big end's. Even if they are standard size bearings & the crank journals measure up. Remember to check the crank main's & big end journal's in two spot's, 90 degress apart. If you've got the tool's also check both the main's in the block & the big end's in the rod's to make sure all is round. You never know, you might have a big end out round. Touch wood.
    Once you've measured all the bearing's then check the end float of the crank(if you've got the tool's) as this is often overlooked by alot of people on alot of engine's, especially with auto trans, as not only does the trust bearing wear out, the crank thrust surface can wear out too.
    Also check the clearances dry. Don't put any oil on anything when you're checking measurements & don't turn anything. Once you've check it, clean it all down, lube it up & away you go.
    Before you put the crank in, also check the rear main surface as I've seen the seal can get very hard over long period's of time & eat into the crank's surface. Might need a speedy sleeve.
    brackie Guest
    Big end wear
    It's good that you used a micrometer to measure and check the big end journals, Smithy. Plastigauge is good but a fine touch with the mic. is better. As well as checking for ovallity, look for scoring. If it's light you can have the journals polished. On reassembly cleanliness is next to Godliness. Work on a spotless surface with cleaned tools and lightly oil the shells as you fit them. Check for bearing crush too. (Tighten to torque if they're not stretch bolts and slacken the bolt off on one side. You should be able to get a 2 or 3 thou feeler between the conrod flanges.) Remember the stress that diesel cranks have to endure and fit everything carefully and to the correct torque.
    Camden, Sydney
    Sounds like you are ready to bolt it back together smithy.
Similar Threads
  1. Bottom Skirt Clips for Mk1
    By barrygti in forum Mk1 Golf
    Last Post: 04-03-2007, 04:19 PM
  2. Mk1 Brakes...advice plse
    By gmhendo in forum Diesels
    Last Post: 04-02-2007, 04:20 PM
  3. jacking up a mk 3 - advice
    By golfvr6 in forum Mk3 Golf & Vento
    Last Post: 13-02-2006, 09:22 PM
  4. Torque setting for bottom end
    By 82cab in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 10-11-2005, 09:55 AM
  5. mk3 bottom end for a mk1
    By alex g in forum Mk2 Golf & Jetta
    Last Post: 15-10-2005, 01:23 PM
