Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: The best method of "caging" a mk1..
  1. #21
    Jan 2010
    Baulkham Hills
    I'VE CREATED A MONSTER!! haha
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
  2. #22
    Feb 2006
    Perth Western Australia
    I'm with you peter, as for the seamless tube which still won't pass for any techinical reason um yes there is, it is the carbon and iron content within the metal that is the reason they won't pass it because the higher the carbon and lower the steel content of the steel means the weaker it is mate (the cheapest stuff from india is the main culprit of this). The roll cage tube is all low carbon and must contain a certain percentage of Fe45 to ensure it is strong enough, which is why they charge more for it. CrMo is an entirely different price range though.
    The little bit extra for the correct steel itself isn't as expensive as having 6 months off work while you recouperate in hospital because they cage did nothing or split and ended up in you!.
    If you want a show cage then go for it at your own peril. Even when i have the front hoop out of my rally car to drive from my house to my workshop the police still pull it over at every chance they get for a scrutineering, make sure your car is perfect otherwise you may as well start lining up the RTA to have the defect stickers removed now
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
  3. #23
    Oakleigh VIC
    So, back to the original question - The best method of caging a MK1 is to engage an automotive engineer who specialises in the design and manufacture of roll over protection systems.
    I'm using Brown Davis, in fact the car is booked in for this Friday and yes, they will do all the calculations, build it out of the right materials and it will be fully CAMS compliant.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  4. #24
    Jan 2009
    south west sydney
    all OP want's is a half cage that makes his mk1 look more agressive.
    i'd be looking at the bolt in jobs from europe or the states if you can find them. getting an engineer to build some epic roll cage is going to cost thousands of dollars isn't what you need.
    obviously you need to speek to your local road authority before spending a heap of coin on something that may only get you in trouble.
    these types of half cages offer more than just looks too. the chassis stiffening will be very noticeable. for example we have a number of hilux utes at work. all the same year modet etc. but one of them has been built to mine specification which means revolving lights fancy reflective stickers aaaaand a 2 point roll bar. id drives like a road car the others are boats in comparison.
    you can pick up a half cage for an s13 or 180sx pretty cheap.. around $400. it would be interesting to see if one of these could be modified to fit a mk1. would most likely involve a fair bit of fabrication to fit and may end up being an expensive exersise after all... and will it be able to pass road worthy? i dunno.
    look on youtube at home made roll cages.. i remember watching a clip on there of a dude building a cage with a pipe bender some hole saws and a welder... looked pretty good in the end too. could be a fun way to learn to weld. but like people have said i wouldnt want to rely on a bodgy roll cage in an accident.
  5. #25
    Jan 2009
    south west sydney
    here's a pic of an s13 half cage. would be interesting to measure one up.
  6. #26
    Gosford Central Coast NSW
    Thats a big commitment Pete, I'm impressed.
    I can see i've backed myself into a corner on the tubing material side of things, so I wont say anything else - but thanks for giving us all some good clarification Volksee77. It makes sense to me that it would be low carbon, when I've worked with it it does seem to be more ductile than most small diameter pipe (as opposed to tube) which I likely wrongfully assumed was down to a final stress relieving (heat treatment) after it is formed.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  7. #27
    Feb 2006
    Josh, check out OMP in europe, they make FIA compliant steel cages that don't cost the earth. A 6 point basic steel cage costs around $800(not including postage) so i imagine a half cage would only set you back half that but the plus is it will look like a proper cage, bolt straight in and being it has 4 points it will begin to stiffen the car up (a 2 point will do squat).
    89 porsche 911
    80 Rabbit 4dr
  8. #28
    Oakleigh VIC
    Quote Originally Posted by Volksee77 View Post
    Racer Industries import a lot of the OMP stuff here, might be worth giving them a call and see if they can get it in for you. Racer Industries
    7? MK1 Caddy
    12 Amarok
  9. #29
    Sep 2009
    Chillaxing in Tas
    <space for rent>
