Results 1 to 5 of 5
Thread: Bent rear stub axle
    Aug 2006
    Upper Ferntree Gully Victoria
    Bent rear stub axle
    Is bending rear stub axles common? we bent one at a rally on the weekend which gave us 10mm toe out The beam was undamaged To fix it I machined it in the Lathe between centers The alignment is ok now but wodering if I should start looking for spares Thoughts?
    MK1 RALLY CAR
    SUPERCHARGED MAZDA323 AUTOCROSS CAR
    Apr 2006
    Hobart,Tas
    I haven't ever bent one. You would think that if it was to bend, the wheel brgs would chop out as they are a lot thicker on the flange end. It is exremely hard to detect a bend in the rear beam arm but I suspect that is probably where it has bent. Doesn't take much of a bump to move them as they are hollow, unlike the hardened steel stub. Thats my thoughts.....
    Camden, Sydney
    Good call Andrew. I`ve never seen a bent stub axle. The beams do bend though. I`ve got a couple here if you get stuck.
    Please post up your location too please Mr Gumboot
    Aug 2006
    Smile Stub axle
    Thanks for your replies the reason I asked is because the golf manual I have has a page on "checking for bent stub axle " showing a picture of a stub(off the car) square and a vernier I thought it was strange too hence my question
    We will be testing on the weekend so Ill see how it goes thanks for your offer loon if I need one Ill contact you
    I live in upper Ferntree Gully Victoria
    MK1 RALLY CAR
    Mar 2006
    brisbane
    bent
    i havent bent an axcel per se but did hit a gutter sideways at 50km and the wheel was poking out about 30mm more on the other side hehe
    not sure exactly what tweaked..the car looked funny either way!
Similar Threads
  1. Removing rear window mk2 gti
    By ausgolfer in forum Bodywork/Trim & Detailing
    Last Post: 19-01-2007, 10:13 AM
  2. Rear Axle On My MK2
    By MK2 GTI in forum Mk2 Golf & Jetta
    Last Post: 12-05-2006, 07:12 PM
