I have just got the golf on all fours and taken it for a test drive. When the engine is off, 2 pumps of the brake pedal leads to a solid pedal. With the engine running, the pedal sinks to the floor and I only get 'braking' at the very end of the pedal movement.
This probably shows I have air in the master cylinder still........
I am using my power bleeder and, on my 2 previous master cylinder changes, I never had to bench bleed the m/cyl. Any tricks to getting air out while in the car?
I have heard you can pressurise the system with the power bleeder, crack open a nipple and then depress the pedal a couple of times.......
For those, who haven't read my build thread, I have new brakes all round and a new booster/master.
I would have thought that, as the pedal becomes easier to push with the car running, the booster would be fine? Am I wrong in that assumption?
Sometimes the old ways are the best. Get a friend to pump and hold the pedal while you bleed at the brakes. I've found the power bleeder can't always force the air out of a system.
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
