Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: Beige Mk1 golf 1.8t 20v The Rebuild!
  1. #51
    Aug 2013
    england
    to update i fitted the g60 front brakes haven't tried them yet just hope they perform ok after having the wilwoods fitted
    at least now i can run without the need of a large spacer
  2. #52
    Aug 2013
    england
    so to update fitted the H&R's they ride awesome still yet to set the height exactly where i want it tho
  3. #53
    Aug 2013
    england
    To update my new wheels arrived 16" bbs rs's i had the lips and barrels changed so i could run the off sets i wanted
    Attached Thumbnails Attached Thumbnails Beige Mk1 golf 1.8t 20v The Rebuild!-2qknl1z-jpg
  4. #54
    Aug 2013
    england
    refurbed my anti roll bar when money allows it will be upgraded
    my chrome brackets arrived
    all fitted with stainless steel outer brackets
  5. #55
    Aug 2013
    england
    I also tok the car out to check the new wheels clear etc but broke the new inner cv joint ! the shaft is to long and the cv joint cant take it
    so im having a custom shaft made up
  6. #56
    Aug 2013
    england
    Custom shaft made from scratch 20mm shorter
  7. #57
    Aug 2013
    england
    Its was time for another show Players classics at goodwood race circuit
    a few pics from the show
    i won a trophy to
  8. #58
    Aug 2013
    england
    so to update a little it was time to change a few things 1st up some more chrome
    wipers and some caps
    I needed to go a little lower so i had to notch the drivers side you can see the rub marks on the shaft
    so i stripped that side out
    what the chassis looked like
    i then marked out the ares and cut all the way through the chassis leg, cut metal tube to size and began welding it in
    i also welded a plate above it for extra strength
    primed it and seam sealed it
    and painted it
  9. #59
    Aug 2013
    england
    Next up was the fuel pump i was running a pump and accumilator in the boot as my lines run inside the car, this made the car smell of fuel so time to change it all
    the old pump
    i needed to change the fuel tank to a gti tank as it was running the old 1.1 tank with pick up pump in the tanks
    so i sourced a gti tank
    bought a new bosch pump this one is good to run upto 500 bhp
    out came the old tank in with the new one
    i made up a mounting bracket for the pump and another for the filter and added teflon braided hose
    no more bad fuel smells
  10. #60
    Aug 2013
    england
    Went to another show and won the people choice car of the show
