This is an unreal build, awesome job. Where did you get that chrome bonnet catch/pins from?
small update the car by this time was in being painted
all my chrome engine bolts have arrived
my adjustable camber/caster top mounts have been deliveried im very happy with them
small update when i removed the engine and box i tried the turbo shaft for play and was happy with the way it felt, since then all ports throttle inlet etc have been covered up, i changed the cambelt and decided to inspect the turbo ive found 4 out of the 6 outer blades are bent ! something has been drawn in and damaged them in its life time.
I ordered a genuine turbo to replace this one i did try a ko4 but the pipe work would of fouled the driveshaft so i stuck with the ko3
so to update the rebuild was well under way at this time, there was just two weeks till the first show of the season!!
the paintwork is amazing heres a few shots
engine back in and running
so ive been busy rebuilding the car as i have been picked for ultimate dubs heres a few little shots
the bay almost finished
So it was crunch time it was the thursday before the show it wasnt road worthy for the 400 mile round trip so i trailered the car to the show, but i had made it the car was good enough to show just 23 weeks after stripping the car it was rebuilt
here are some phots from the show ultimate dubs
The car was in the feature section the theme was mk1's i was so happy
this is not the end of the build tho theres more changes to come
