Coming along nicely
a quick build up of the car to check panel gaps etc alls good im very pleased with the car so far
Coming along nicely
so there were a few places on the car needing attention these were done and the car was sprayed in high build this was done just before christmas 2012!
so today i painted the whole car in high build primer im soooooo happy with it all it really is a turning point and i now know it will be ready for painting in january
just a few spots need very fine attention
Next up was the engine and gearbox it was running a really low ratio box so i sourced another box so i can hopefully get some more power down so i found a gearbox with the code i wanted ENJ this has a higher ratio than the current gearbox and will allow a better cruising speed
gave it a quick clean
so ive removed the gearbox and checked the clutch it has hardly any wear but does have a little bit of movement in the centre drive so il replace it
carrying on with the colour coded parts theme the paint on the oil filter housing is looking shabby to so ive removed it ready to treat and paint
re-sealed the joins on the inside of the bonnet instead of the horrible factory stuff that was all un even
update paint stripped the oil filter housing so it can be painted
then etch it
then sprayed it and covered it with a satin laquer
picked up the new gearbox from the shot blasters
and etch primed it
gearbox sprayed
new starter motor stripped ready to repaint
alternator stripped to repaint
painted
and the starter painted
new larger rear lips arrived
and fitted
new alternator pulley
chrome starter motor bolts
the best part though its gone to the bodyshop for paint
a few photos of it leaving work and of course it was pouring with rain so i covered it up
