Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 62
Thread: Beige Mk1 golf 1.8t 20v The Rebuild!
    Aug 2013
    england
    a quick build up of the car to check panel gaps etc alls good im very pleased with the car so far
    Jun 2012
    Goldcoast qld
    Coming along nicely
    Aug 2013
    england
    so there were a few places on the car needing attention these were done and the car was sprayed in high build this was done just before christmas 2012!
    so today i painted the whole car in high build primer im soooooo happy with it all it really is a turning point and i now know it will be ready for painting in january
    just a few spots need very fine attention
    Aug 2013
    england
    Next up was the engine and gearbox it was running a really low ratio box so i sourced another box so i can hopefully get some more power down so i found a gearbox with the code i wanted ENJ this has a higher ratio than the current gearbox and will allow a better cruising speed
    gave it a quick clean
    Aug 2013
    england
    so ive removed the gearbox and checked the clutch it has hardly any wear but does have a little bit of movement in the centre drive so il replace it
    carrying on with the colour coded parts theme the paint on the oil filter housing is looking shabby to so ive removed it ready to treat and paint
    Aug 2013
    england
    re-sealed the joins on the inside of the bonnet instead of the horrible factory stuff that was all un even
    Aug 2013
    england
    update paint stripped the oil filter housing so it can be painted
    then etch it
    then sprayed it and covered it with a satin laquer
    picked up the new gearbox from the shot blasters
    and etch primed it
    gearbox sprayed
    new starter motor stripped ready to repaint
    alternator stripped to repaint
    painted
    and the starter painted
    Aug 2013
    england
    new larger rear lips arrived
    and fitted
    Aug 2013
    england
    new alternator pulley
    chrome starter motor bolts
    Aug 2013
    england
    the best part though its gone to the bodyshop for paint
    a few photos of it leaving work and of course it was pouring with rain so i covered it up
