Page 10 of 10 FirstFirst ... 8910
Results 91 to 99 of 99
Thread: Beige Be Born!
  1. #91
    Sep 2009
    Chillaxing in Tas
    New Lifters in, no more ticking, YAY!!
    New Cover gasket and cam seal, no more oil leaks..... from there atleast LOL
    Got to bleed brakes then go drive it. Need to tune the weber for the new engine.
    <space for rent>
  2. #92
    Sep 2009
    Chillaxing in Tas
    sent more time on the weber today, need to invest in some jets,
    as i only have enough to mix around in primary side. which is ok as majority of driving is done on that side.
    Goes alright, will break traction in first easy, would do 2nd but damn clutch is slipping, any have a spare 210 mm clutch plate? LOL
    Getting sick of the ride height, i do have some JOM coilovers in the project car, which is no where near finished. so might pinch em till i can afford something like weitec or something. (looking at you Preeny!!! )
    quick vid, sounds tuff
    <space for rent>
  3. #93
    Feb 2006
    Devonport, Tasmania
    Hey bro whats the MSD limiter you mention in the title of the vid?
    2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
    1986 SAAB 900 Turbo 16 S
  4. #94
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by tassie_euro_mk1 View Post
    MSD 6AL ignition box,
    Got a steal on ebay ages back, never got around to fitting it intill few weeks back.
    Works well, better idle, smoother, revs cleaner
    <space for rent>
  5. #95
    Sep 2009
    Chillaxing in Tas
    So ive had spongey brakes for a while now,
    I think it was down to a worn Hardline from MC to Rear drivers corner.
    It snapped off near the MC, Made up a new line (what a prick, and it looks ****. Function over form atm though)
    Off to bleed brakes this morning.
    On a side note, still Putting away at jetting this damn carb
    Think i really need to invest in a AFR gauge, or a dyno run.
    Alot of setups ive seen people arent going 140 main in primary , maybe a 145 with a bigger cam.
    Mine feels best with a 150main and 170 air 55 idle in primary side, havnt started tuning second side yet.
    <space for rent>
  6. #96
    Sep 2011
    melbourne
    i may have to look at a msd limiter my self !
    i've got a heavly worked 1.8 8v on a 04a 5sp quaife diff that will be comming out of my mk1 soon if you inerested..... it'l rev to around 8500 it's a very quick motor massive rally cam 50mm delorto long manifold extensive headwork high compression !
  7. #97
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by knupflog View Post
    PM'd!!
    Yeah the msd is nice, can really notice the difference when you connect it. Easy starts, smoother, idle is steady, throttle response in low revs better due to bigger spark. I like it
    <space for rent>
  8. #98
    Jun 2006
    Orange NSW
    Quote Originally Posted by GRN_VAGN View Post
    Good to hear the old 16v lifters did the job for you, dude.
    MSD 6AL is a full ignition box with a limiter in either a pill (resistor) or an adjustable dial.
    I have a 40th anniversary 6AL in the box, never used at the workshop, actually...
  9. #99
    Sep 2009
    Chillaxing in Tas
    Thanks bud,
    Yeah drove around for an hour yesty, not a tick to be heard
    <space for rent>
