Results 1 to 10 of 15
Thread: Battery light and radio static
    Aug 2009
    Torquay, victoria
    All of a sudden my battery light is staying on but does decide to turn off every so often. I am guessing the radio problem is in conjunction with the battery light?? When the revs are up the radio has static but when just at idle it goes!! Any ideas??
    Aug 2009
    I'd be checking/cleaning your earths man!
    BTW: you still seeking a spare flywheel?
    Aug 2009
    Torquay, victoria
    Just noticing now when it's at idle the light is off and then comes on when driving!!
    Feb 2007
    Check your ground conections as stated, check the voltage that the alt is putting out.
    It could be that your alt is stuffed or the regulator isnt working. If your reg isnt working on your will cook your battery, but you would have already smelt that. Also check the blue wire is ok on the alt, thats the one thats connected to the light on the dash.
    MK1 GLS 3door
    A4 B7 2.0T
    Aug 2009
    Torquay, victoria
    So where are all the earths so I don't miss one? Found the battery one and the alternator one. Where are the others? Also what voltage should my alternator be putting out?
    Should be topping 13volts, more than 14 is bad.
    Take the regulator off the alternator, my guess is the brushes are worn down. Clean the commutator too, some fine wet and dry or wire wool would be ok to use.
    You could clip an earth from the alternator body, to the battery and see if it fixes it.
    Feb 2007
    Quote Originally Posted by lawny View Post
    Like h100vw said it should be about 13volt, its not going to be alot even if its working properly. 14.7 is when most batteries start cooking.
    If you take the reg off (its the thing on the side of the alt held on with 2 small screws) you can tell is stuffed if the brushes are short, they are usaly about 3-4cm long.
    There should be a earth just behind the battery, kindo under the window washer bottle and in line with the bumper mount bolts. It should go from there to the battery and to the gearbox or engine. Always good to upgrade them anyway.
    MK1 GLS 3door
    A4 B7 2.0T
    Aug 2009
    Torquay, victoria
    so i took the regulator off and yeah it looks pretty stuffed, any ideas where to get them from? is it ok to still drive? i havent smelt the battery cooking. this is what it looks like
    Yeah lawny, that's shot. In the UK I'd have gone to a Bosch agent, over here I'd just try an auto-electrics place first before Imparts or whoever you have in Melbourne.
    When cooking the battery was mentioned, it is over charging it which causes it to gas and get hot. If the regulator wasn't working you would see the lights getting massively bright at night, shortly before they blew.
    Feb 2007
    Me and my mate only noticed the battery was cooking in my mk2 when the smell started getting in to the cabin then we saw it smoking from the bonnet.....dont breath it in yeah lol.
    I have a couple of mk1 alts here man, i can check the regs on them if you need one asap. It shouldnt be hard to get a new one though.
    MK1 GLS 3door
    A4 B7 2.0T
