the diesel battery is usually between 500 and 600CCA.
i cant see a problem with paying for a big battery - the benefits are good ones. i've had the same 550CCA battery in my old mk1 diesel, now its in my white LS - for 5 years. its been run completely flat atleast 10 times, and still works fine.
can beat that fast crank and strong spark for cold mornings.
if you shop around you oughta be able to get something above 500CCA for around the $150 mark.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
