The bores were badly rusted and cylinder 2 was full of water, probably from the steam clean. Piston 1 has indentations in it so maybe a ring has let go.
Here is the head. Its in good nick, ready for some big valves and top spec valve gear with a wild cam. Notice lots of burnt oil all over the place. H said last time he had it running it was using oil.
I gave the bores a quick hit with WD40 and some wet/dry to have a better look at the condition they are in. I haven't measured them yet but it should bore out nicely. The rings must be absolutely rooted as the bores are very glazed. This old thing has done alot of work.
