Originally Posted by
sports racer
All aluminium motor? You're talking about the 1.8 20v aren't you. For a minute I was hoping you found a cheap source of aluminium blocks to suit my ABF head.
Why do you recommend 14" wheels? For normal road use I've found 15" with 50 profile to be better handling over 14's with 60 profile tyres. Admittedly I don't race but I do push hard enough through corners to occasionally slide.
14" wheels hive you a much better overall suspension package in a mk1 -touge! A mk1 doesn't have heaps of suspension travel on the front, and the extra tyre flex helps to keep contact with the road on bumps.
In my experience, on the road, 14's on a mk1 is faster than 15's. When you can guarantee a smooth road, OK sure you might find some advantages with larger diameter wheels, but roads are typically very bumpy, particularly when you are going fast!
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
