Any updates on this dude?
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
Sorry mate works been hectic the past few months and with the winter months i dont drive it much. Done a few things when I get a break here n there...
Added a Kamei rear spoiler( had to buy 2 to get the clips, seller didnt want to split)
Added some engine covers( not sure if its staying tho)
Also bought this....
She still looks the same tho
Broke the passenger side inner cv a few weeks back, so changed the cv's to the bigger 100mm outers to match the inners. Now there's some type of whirring noise coming from the front. Changed wheel bearings but still there. Anybody got any ideas of what it could be? I'm thinking of changing back to the 90mm outers and see if it goes away.
Leigh
Check that the outer cv is not rubbing inside the upright/bearing housing as on some there is minimal clearance for 100 mm cv's.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
Spoiler looks awesome! Also love the engine covers, makes it look modern and tidy.
Only my driver's side rubbed but used a dremel to remove the metal on the housing. The whirring/bearing noise is still there. Is there suppose to be some play in the shaft? Mine is tight with no movement.
Shouldn't be any movement. One end is bolted to the gearbox and the end with the spline is held (very) tight in the hub with the locknut done up to 5 gazillion pounds torque.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
If you ran it for some time with the metal to metal interference then you may have damaged the CV or wheel bearing.
Also, what is the actual inner CV. outer CV, driveshaft combination?
The driveshafts that came with 90mm inner CVs were longer than the proper 100mm inner CV driveshafts. This is because the 90mm flanges on the gearbox sit shallower than the 100mm flanges.
One of the cheat's ways of using a 100mm inner CV on a driveshaft that was built for 90mm inner CVs was to put the driveshaft in a lathe and clearance the splines so the larger 100mm CV can fit on. However, that still means the driveshaft is still longer than it should b,e which will put undue force and tension on the CVs. This is particularly a problem when you lower the car.
In short, if you are running 100mm inner CVs and 100mm gearbox flanges then you should get the matching 100mm Mk1 driveshafts (Mk2 shafts are different again!). If you only have 90mm driveshafts, I would switch the gearbox flanges to 90mm and the matching CVs.
Here are the bare driveshaft lengths (from clubgti)
Golf 1 (90mm inner CV and flanges)
Short shaft: 445.5mm
Long shaft: 658mm
Scirocco / Golf Cabrio (100mm inner CVs)
Short shaft: 430mm
Long shaft: 650mm
