Results 11 to 20 of 21
Thread: Back in a MK1!!!
    Dec 2008
    Baldivis, WA
    Wont be a daily, more weekend cruiser. Club permit in WA is way different than Vic.
    Thanks man! Cheers
    '81 MK1 Golf GTI
    '15 VW Golf R Wolfie
    Jan 2010
    Melb Westsideeeee
    Any updates on this dude?
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Dec 2008
    Baldivis, WA
    Sorry mate works been hectic the past few months and with the winter months i dont drive it much. Done a few things when I get a break here n there...
    Added a Kamei rear spoiler( had to buy 2 to get the clips, seller didnt want to split)
    Added some engine covers( not sure if its staying tho)
    Also bought this....
    She still looks the same tho
    Broke the passenger side inner cv a few weeks back, so changed the cv's to the bigger 100mm outers to match the inners. Now there's some type of whirring noise coming from the front. Changed wheel bearings but still there. Anybody got any ideas of what it could be? I'm thinking of changing back to the 90mm outers and see if it goes away.
    Leigh
    '81 MK1 Golf GTI
    Jul 2005
    Check that the outer cv is not rubbing inside the upright/bearing housing as on some there is minimal clearance for 100 mm cv's.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Jan 2010
    Melb Westsideeeee
    Spoiler looks awesome! Also love the engine covers, makes it look modern and tidy.
    Feb 2006
    Melborune, VIC
    Quote Originally Posted by aprr32 View Post
    What he said. The bearing housings are different between the 90mm and 100mm outer CVs. You can use a die grinder to clearance them, or a mill, if you have it.
    Dec 2008
    Baldivis, WA
    Back in a MK1!!!
    Only my driver's side rubbed but used a dremel to remove the metal on the housing. The whirring/bearing noise is still there. Is there suppose to be some play in the shaft? Mine is tight with no movement.
    '81 MK1 Golf GTI
    Shouldn't be any movement. One end is bolted to the gearbox and the end with the spline is held (very) tight in the hub with the locknut done up to 5 gazillion pounds torque.
    Feb 2006
    Melborune, VIC
    If you ran it for some time with the metal to metal interference then you may have damaged the CV or wheel bearing.
    Feb 2006
    Melborune, VIC
    Also, what is the actual inner CV. outer CV, driveshaft combination?
    The driveshafts that came with 90mm inner CVs were longer than the proper 100mm inner CV driveshafts. This is because the 90mm flanges on the gearbox sit shallower than the 100mm flanges.
    One of the cheat's ways of using a 100mm inner CV on a driveshaft that was built for 90mm inner CVs was to put the driveshaft in a lathe and clearance the splines so the larger 100mm CV can fit on. However, that still means the driveshaft is still longer than it should b,e which will put undue force and tension on the CVs. This is particularly a problem when you lower the car.
    In short, if you are running 100mm inner CVs and 100mm gearbox flanges then you should get the matching 100mm Mk1 driveshafts (Mk2 shafts are different again!). If you only have 90mm driveshafts, I would switch the gearbox flanges to 90mm and the matching CVs.
    Here are the bare driveshaft lengths (from clubgti)
    Golf 1 (90mm inner CV and flanges)
    Short shaft: 445.5mm
    Long shaft: 658mm
    Scirocco / Golf Cabrio (100mm inner CVs)
    Short shaft: 430mm
    Long shaft: 650mm
