Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: Audi S3 vs VW 4Motion...
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by Lima View Post
    8L 165kW post MY02, 154kW pre MY02 (1.8T)
    8P 188kW Aus spec, 195kW Euro spec (2.0T)
    AFAIK both use a variation of a K04 turbo.
    it was only the 2000 S3 that had 154kw , 2001 had 165 kw
    The 2000 used KO4-022 while the 2001+ used KO4-023 . Main difference was 2001+ was wideband and with EGT in exhaust housing of the turbo ...
    Bug_racer supports the rebellion of the euro revolution
    Oct 2013
    ACT
    Just went searching around for those engine codes and found something interesting. AUDI S3 3.2L(VR6 Engine) QUATTRO!!!!!!!!!!!
    the Vr6 should fit shouldn't it??
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by Mk1@4Motion View Post
    Its not officially an S3 , just an A3 . Also Im pretty sure they are all DSG
    Oct 2013
    ACT
    Fark, I'M SO CONFUSED!!!
    Oct 2013
    ACT
    Which codes can be found in Australia?
    Who can tell me what codes are available in OZ?
    Audi A3 - Wikipedia, the free encyclopedia
    Attached Thumbnails Attached Thumbnails Audi S3 vs VW 4Motion...-image-jpg   Audi S3 vs VW 4Motion...-image-jpg
    Jul 2013
    I know BAMs, AGUs and APYs/AMKs are available in australian delivered A3's, S3s and TT's.
    I thought the difference in power between a BAM and APY is just tune, they will both make similar power after you get an aftermarket tune.
    Sep 2010
    Wheelers Hill
    I'm pretty sure that engine came in the TT, I'm sure it's the first dsg car from audi/vw
    Sent from my GT-I9505 using Tapatalk 2
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
    Jul 2013
    There's a couple guys on Audi-sport for have put mkIV r32 engines in s3's so should fit!
    Oakleigh VIC
    I'd strongly recommend seeking advice from an automotive engineer to see what's possible before you start.
    It'll save you a lot of hassles with registration and compliance if you get the advice early.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Oct 2013
    ACT
    Can anyone tell me if the APY, AMK, BAM engine does come in A3 Quattro's. A lil busy at work so I would really appreciate an answer on this cause I might be able to get either one of them and then just need the rest later
