Or it could be something simple like the number of laps each worker thrashed your car around the block before delivery.![]()
Thought this was pretty Cool.
Found it in the New golf when i was cleaning and rewiring behind dash.
just remembered it today so thought id google it,
Arbeits-Anweisung
Google Translate
Not sure if this is correct or not, but it seems pretty cool. a Check list for the workers on the car maybe?
So, have always wondered what the little tag next to the compliance plate on rad support is.
From what i can tell its the build date and production number.
first 2 numbers are the week it was built, 3rd is the day of week (unsure when the week starts, still searching.. guessing monday?)and the last 4 are the build number.
http://www.golf1-ig.de/golf/facts/co...tive/index.php
Also Found this in relation to the small tag next to compliance plate.
"- Now let's check the color code, if you see the 4th picture, you will find a plaquette in which are printed these sequence number:
252 - 0733
D5 2 0
252 plannig date prod and/or production date: 25th week of 'solar' year 1978 2nd day of that week. --> For ISO and EU means 20 June 2978. For US just one day before: 19 June 1978!!!! Almost 1 month from production to import and to the final customer!
0733 733th car for that day (not sure but some other experts think so: some kind on sequence serial number inside the production plan/day)
D5 --> Brochure Code (check one of yours, to confirm that!) for Dakota Beige original color.
2 0 ----> Don't know (may be production plant ..etc..)"
info from here http://www.vwgolfmk1.org.uk/modules....wtopic&t=50758
<space for rent>
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
WOW, that is cool it is the old school version of the options on the car.
The modern ones are not much different.
Maybe you should order a birth certificate?
:: Volkswagen AutoMuseum :: Certificate Generator
LMAO!!!
I did bit more reading, few other people have found them.
That get stuck to the top of the glove box when built.
People complained of a "rattle whistle" noise around that area and most got removed.
Its cool to know anyway, if i worked it out right, my car was 'born" Monday the 15th of January 1979![]()
<space for rent>
