Results 1 to 7 of 7
Thread: Another go at fixing it
    Dec 2005
    Well I took the inlet manifold off today.... it was actually a peace of p...
    I needed to buy a 6mm alen key socket and borrowed the neighbours 5/8th to half inch adapter.
    My questions are.... what type of gasket material do I need to buy? Is the thick cardboard stuff ok? Or is it special material i should use?
    and
    I stuck my finger into the inlet port and in the last 2 u can feel a little bit of rubber hanging from the top of the port but in the first 2 there is nothing anyone know what it is and if it is missing two?
    cheers
    Lee
    brackie Guest
    Gasket
    Get the proper one. It's not worth making your own as if you get it wrong you could end up with a manifold leak that would make it untunable. Clean the manifold and the head thoroughly with a blade. When fitting it smear a very light coat of silicone on both sides. This helps stick it to the head. Torque it accurately.
    Hope it goes well
    Dec 2005
    I know all about manifold leaks! It still drove... just.....
    Where should I look to source a proper one though. Its using a LYNX manifold. I wouldnt think this part would be easy to come across. Autobahn/repco have NFI what im talkin about when I ask them...
    Apr 2006
    Hobart,Tas
    Still takes the original gasket to the head. Any VW workshop would have them. PM me if you need one from this end. Benaiah got my last one wednesday but have ordered some more. Try a local source first. Cheers!
    Dec 2005
    ah, original fit. Will try local on monday. Cheers
    Camden, Sydney
    Even repco or supercheep would have em.
    Dec 2005
    Bought a gasket from mk2 gti from this forum. He works in his dads shop down the rd from my place. Anyways, I found out that the little blobs of silicon in the inlet port are from a dodgey install. The installer of the motor filled the injector holes that go into the inlet port with silicon. He put a bit to much in and some ran down and into the inlet port. Surely there would be a better way other than silicon to fill the injector holes
    Put it all back togethor and it still ran pretty bad. fiddled with the dellorto some more and it seems to be running nice now. Time will tell..... im not real confident driving it far but it seems to be ok
