Alternator theory.
When you start the car the alternator needs a small amount of voltage in the blue wire, the field.
This starts the alternator working. The blue wire comes from the warning light on the dash. When the voltage out of the alternator matches that on the other side of the warning light. It goes out.
Your alternator is working fine. In the old days before LED warning lights, you could change the wattage of the warning light to control when the alternator kicked in. Essentially it was related to engine speed.
You might find that a new regulator pack and brushes will put the light out without revving the engine but don't count on it.
The reason the voltage drops of is the juice required to start the car.
