Results 1 to 9 of 9
Thread: Alternator Confusion - Need help!
    Gold Coast
    Hey Guys,
    My alternator has failed. Probably because I degreased the engine, but anyway, I need to get a replacement and I've been unable to find a part locally.
    I've trawled through all of the parts sites, and it seems Rock Auto has plenty to choose from. Problem is, I'm not entirely sure which part to go for. I've contacted them directly, but they are pretty much no help. I guess because most of the parts are repro so they have no idea.
    I'm pretty sure it's one of these two options:
    1983 VOLKSWAGEN GOLF 1.8L
    KLARIUS/QUINTON HAZELL Part # 9033760 {#FRA102} FRIESEN; Voltage [V]: 14; Alternator Charge Current [A]: 55; Belt Pulley Ø [mm]: 65; Fastening Type: Single pivoted lever; Distance / Ø [mm]: 110; Reman
    Hatchback, eng code [DX]; Convertible, eng codes [EX], [JH]
    1983 VOLKSWAGEN RABBIT 1.8L
    ACDELCO Part # 3211251 {#10463694} Reman; 55:AMPS; 55:AMPS
    GENERATOR, BOSCH, IR(IC) & EF; REMANUFACTURED; w/o A/C
    I have the DX engine in my cabriolet, hence I'm leaning towards the first one, but the current part is a Bosch 14v 55A alternator and looks just like the image on the left here (from the second part):
    I can't tell what the first one looks like, although it could also be the same.
    Anyone been through a similar process who can help?
    Cheers,
    Dan
    Dan P
    1983 Mk1 Golf GTI Cabriolet
    May 2010
    NQ
    Alternators are, generally, completely rebuildable.
    Being a Bosch alternator, any competent auto eleccy should be able to rebuild it for you.
    They're just a regulator, 2 bearings and some copper wire.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Feb 2006
    Melborune, VIC
    Yes, just rebuild it. Works out a lot cheaper and you can get the casing coated/polished/painted while its apart to make it look pretty
    Oct 2010
    2095, Manly
    Might be an idea to change the regulator first
    76 Mk1 4DR SOLD
    01 B5.5 Passat Wagon SOLD
    84 Mk1 GTI
    Gold Coast
    Well quotes for fixing it range between $250-500.
    It's going to be cheaper for me to buy a part from overseas.
    Dan P
    May 2010
    NQ
    Quote Originally Posted by danpez View Post
    Is that if you supply them with the alternator already removed?
    HAHAHA
    Gold Coast
    That's what I said to him. Even if it's half that, I can get a replacement for $120.
    Dan P
    Jun 2006
    Orange NSW
    Try another mob. Someone should do it cheaper than that.
    I have a could of alternators kicking around if you need one. I can get it tested before I send it. Haha.
    Feb 2006
    Melborune, VIC
    Who does them for $120?
