Page 10 of 10 FirstFirst ... 8910
Results 91 to 98 of 98
Thread: Alex's GTI Project
  1. #91
    Hey all just letting you know i am putting my mk1 EOI
    http://www.vwwatercooled.org.au/newf...ad.php?t=41134
  2. #92
    Nov 2006
    Canberra, Australia
    Wow. Good luck with the sale. It looks very bloody nice.
    Given I also looked at buying this car I might be able to help out with any questions prospective buyers might have as well.
    MY10 S3 3dr
  3. #93
    Quote Originally Posted by Lima View Post
    You are Mk1 Gti collector, Liam
  4. #94
    Nov 2006
    Canberra, Australia
    Haha, no not at all. I looked at the car around this time last year. It drove really nicely, but the bodywork issues were beyond my scope. If I had access to panel beating like Alex I would have been much more interested.
    In fact, here's the old FS thread...
    http://www.vwwatercooled.org.au/newf...ad.php?t=28810
    MY10 S3 3dr
  5. #95
    Ok so i went for a little drive tonight, a trip to the seven 11 turned in to a 3 our cruze along the beach and highway, i am really enjoying the suspension and ride, but i think the time has come for some engine work to be done.
    the car is going in next week, to get the roof re trimmed and interior done up a bit, so after that it is free to hit the garage.
    what do i need to do to get this thing running back up or above its original state? i have heard from a few people k-jet and stuff not 100% on what it all is, or am i better off taking it to volkspower?
  6. #96
    Jun 2007
    Eastern Suburbs Melbourne
    Without knowing what you've done to it already, here's what I'd do. Maybe it just needs a good service and tune (I'm guessing you've had that done though)
    Is it a 1.6 or 1.8L?
    If it were a 1.8L. I'd just get the head rebuilt with some minor porting and polishing. install a slightly larger cam (270-276 deg). Get the block checked & new bearings/piston rings. Install A larger throttle body, (along with port matched intake manifold), some bigger Kjet induction gear (off a Volvo) & fit some extractors and a 2" exhaust.
    You could do the same to a 1.6, but the gains wouldn't be as significant. It would still rev hard & be a ball of fun though!
    Providing all the Kjet bits you have are in good working order, Kjet is great! And it's what the GTI's came with, so even better imo.
    i like volkswagens
  7. #97
    thanks, yeah it has the 1.8 in it, i haven't really touched the engine much just got my mechanic to clean it up a bit
  8. #98
    Sorry to say Jarred. That cam is a major down grade!
    GTI cam with stock "real" G-grind cams which were a solid cam with
    (people oftern confuse the mk2 cam with "G" stamped in it as a G-grind which is far from it)
    283° advertised
    225° at 0.050"
    0.423" lift
    Question Alex. How much do you want to spend?
    Thats the first thing you need to decide on & then you can work out what mods to go for.
    If you start off & say mild upgrades, which is relatively cheap to some, but if your after 160hp, then the cost will increase dramatically.
    This was my old setup with a US spec GTi low compression engine which made roughly 100whp & ran as fast as US spec G60's over the 1/4.
    GX with the compresion raised to 9.4246:1 Corrected & balanced with the clutch/flywheel assembly.
    - Autotech 270 Cam
    - Autotech Heavy Duty Valve Springs
    - Autotech Vernier Pulley - retarded 1-2°
    - Autotech Intermediate Pulley
    - Stage 1 Ported intake manifold from this bloke http://www.scientificrabbit.com/
    - Match Ported Audi Throttle body
    - Volvo 240 2.2L Fuel Distributor & Airflow sensor flap assembly, swiss cheesed airbox, K&N air filter & rocker cover breather blocked off. Now routed into a filtered Powerade Bottle!
    - Late Model stock GTI distributor without vac. advance. (Can't remember ignition timing spec, approx stock 3° ATDC)
    - HD 210mm clutch kit
    - Very old Hurricane 4-2-1 Extractors
    - 2" exhaust system, hotdog (can't remember the length) & straight through offset rear muffler with 2.5" tailpipe
    - 4 spd Stock Diesel gearbox with a ABD short shift kit & weighted shifter rod.
