Results 1 to 8 of 8
Thread: Air Suspension
    Oct 2013
    ACT
    Air Suspension
    Hi there,
    I found out today that air suspension is allowed on the car. So that is on the up side.
    Anybody who can answer the following please do and please if you can, can you upload pics of your car.
    The question/s:
    Did it affect your driving comfort, and how bad/much better did it get?
    Did it affect your steering, and how bad/much better did it get?
    The reason for me asking is because my engineer asked me why I wanted to do it, and I told hime because I want to and it will be pretty mad having a Mk1 on bag suspension, and he said it makes the ride not as comfortable and it affects steering.
    Only The Good Die Young 45
    For a better ride, go WIDE!!!
    VS Commodore V6 Berlina- FOR SALE
    1979 Golf Mk1- http://www.vwwatercooled.com.au/foru...one-92128.html
    Mar 2012
    Central Coast, NSW
    It really depends what kind of setup you get. Air suspension has come a long way.
    Traditionally it affected the handling because when you turn air would transfer side to side in a basic front and back system.
    These days company's like airrex and airlift are making full height and damper adjustable struts that they claim can out perform coilovers. Also allowing a harsh or soft ride pending your setup.
    Nov 2014
    Just be aware of the bump steer and camber change, basically you can have a good alignment at one height, so the other will be off
    Biggest issue with air suspension is the lower you go the softer the spring, and the higher the stiffer, which is the opposite to what you want from a ride perspective (more likely to hit the bumpstops low)
    None of this is really that much of a big deal if you are prepared and set the car up so the standard position is what you actually live with
    Oct 2013
    ACT
    Well, I'll try and set it up that the normal car height is the driving height and then when parked it pretty much lowers the car and thats pretty much it.
    Mar 2012
    Central Coast, NSW
    There's quite a few laws regarding engineering air ride that you should check out. Getting it legal is quite an expensive job - requires expensive management system.
    Oct 2013
    ACT
    I showed my engineer a package I would install if I got a system and he said there will be no trouble as long as it is installed properly and right.
    Jan 2010
    Melb Westsideeeee
    Air ride for mk1 is pretty damn pricey. I'm half way through getting my bits for my cabby and it's been expensive, So be aware of that. The other thing is no one in Aus has done air in a mk1 so it's hard to get any info/personal experience.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Oct 2013
    ACT
    Quote Originally Posted by GeorgeMK1 View Post
    Thanks bud. I have searched around and agree, they are pricey but damn it'll be a mighty fine ride if you can get out at the shops or a cafe and lower it while walking away...
    If I am going to do it I will get either a Bag Riders kit:
    BAG RIDERS | VW MK1 GOLF AND GTI AIR RIDE KIT WITH RIDEPRO DIGITAL MANAGEMENT
    Or I'll get the Air Lift Performance kit:
    https://www.airliftperformance.com/v...olf-1974-1984/
    If I buy the parts separate from one another I will need the engineer to check it all etc and then sort of need him to help install it.
    As far as I know, both mentioned kits are pretty much bolt in kits. Its only the lines and electronics etc that will need fiddle work to make it look neat and make sure it doesn't get busted up during driving.
