Does it cut out when you use only the cd player with the rear speakers not on?
nah engine is working fine
i also had a custom headunit in this before my one with the same setup and wiring to the amp and it had no problem
wabit
it cuts out anytime i use it.... it shuts on and off like it cant hold power
wabit
run a bit of fused 12ga wire from the battery straight to the headunit and ground it straight to the chassis, that "should" fix it otherwise it could just be a faulty headunit.
Hmm I have the same problem in my vr6 its a Pioneer headunit and I'm getting the same scenario as what WABIT is getting I can only crank it to 10 and then the headunit lighting starts to fade in and out like the power is draining, really weird. How much would it cost for someone to look at it.Originally Posted by BlackVr6ix
what state/suburb you in? typically at a Autobarn/Jb/Stratties you'd prolly be looking at ~50
Situated in SydneyOriginally Posted by BlackVr6ix
I would have offered to look at it if you were a little closer to me
LOL thats alright so if I was to take it to strathfield car radios what do I tell them to do???Originally Posted by BlackVr6ix
does the radio actually cut out or just dim?
