Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: aftermarket headunit cuts out????
    Nov 2005
    hey alll...
    i recently bought a kenwood stereo head unit.. and it cuts out like it runs out of power?
    i got it hooked up profesionally but it still does it and the guy dosent know why.... im thinking it is because i dont have a high powerd altinator? my volts meter shows my car is over 12v in charge but its still cuts out.....
    any ideas??
    wabit
    syncro Guest
    Have you got other amps etc?
    Alternator should be OK.
    Aug 2006
    Skye, Victoria
    I used to install audio and stuff so i have a few questions for you:
    When does it cut out?
    Does it only cut out when you have lots of bass or is it totally random?
    How old are your speakers?
    Do you crank it lots?
    Do you have any amps?
    Is it worse at night with the headlights on, or when you have your heater fan blowing?
    Aug 2005
    Prahran, Vic
    wouldnt be the alternator. sounds like a wiring prob somewhere.
    is it turning right off or is the sound just cutting in and out? when does it do it (when you go around corners, braking, or totally random)??
    Nov 2005
    Quote Originally Posted by BlackVr6ix
    1. it cuts out whenever it wants ... today wasnt a problem
    2. my speakers are brand new
    3. i dont crank it at all
    4. one underneath my seat
    5. its random the lights dont make a diffrence but when the radiator fan goes on it sometimes shuts down
    its a 55watt head unit i think but i know 100% theres a 55 in there
    could it be the amp
    also when i put the radio on all 4 speakers work.. then when i put it on CD only the fronts work, whats with that?
    thank you for your answers
    wabit
    Nov 2005
    Quote Originally Posted by joshyd-mk2gti
    all those things except just the sound cutting out... it just powers off
    wabit
    syncro Guest
    Need to put a voltmeter at the HU.
    What model Golf? What type of fuses?
    Where did he pick up the power +?
    Where did he earth it?
    Aug 2006
    Skye, Victoria
    when you put your cd on is it the amp'd speakers that cut out or the ones that are still powered from your headunit?
    Does the display on the headunit dim when there is bass? Kenwood units typically need a good power feed to work correctly.
    55 watts is a WLS (when lightning strikes) rating, if its a current unit (kdc-mp4033, 5033 etc) its actually about 18WRMS.
    Nov 2005
    the display doesnt go dim when bass accurs...
    and also the amp'd speakers whitch are the rears cut out with the cd player
    wabit
    Aug 2006
    Skye, Victoria
    the amp is cutting out because the trigger has been wired to the antenna trigger not the amp trigger, which is an easy fix.
    are you getting any engine noise?
Similar Threads
  1. Aftermarket rims
    By rayray086 in forum Mk3 Golf & Vento
    Last Post: 08-04-2008, 12:31 AM
  2. Polo GTI Headunit
    By mdonohoe in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 04-03-2007, 08:08 PM
  3. Legality of aftermarket ecu?
    By ausgolfer in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 15-07-2006, 08:49 AM
