Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 73
Thread: After a long break.
  1. #21
    Mar 2006
    brisbane
    A little..
    The loom exits out one hole and is covered with that snakelike covering and heatshrink on the ends.
    Rad an manifold are both complete..thanks to a generous friend with a tig. Its for a civic but turned 90deg and had new ports and the filler relocated.
    Found a pulsar brake reservoir at the wreckers. (thanks whoever tipped me off)
    switched to the better hall sensor in the dizzy.
    I had a shipment of parts from the states get lost in the mail and it had the remaining missing parts so im pretty bummed about that.
    Its so close its funny! esp as i go back to NYC next week for another 3 months so i guess its on ice till i return, parts in hand.
    Good luck to everyone with their projects this winter.
  2. #22
    Aug 2006
    Melbourne VIC
    Thats some ripper work
  3. #23
    Aug 2006
    Melbourne VIC
    Hows this one going?
  4. #24
    Mar 2006
    brisbane
    hello.
    I have just returned to aus. pretty keen to get this car moving haha.
    Picked up a pedal box. word on the street is this allows me to delete the brake linkage. good news for dizzy clearance, plus the pedals look good.
    so if anyone wants the booster/cylinder setup i have modified for the mk1, holla. see pics earlier in post.
    more soon.
    brent
  5. #25
    looking forward to seeing more pics and progress
  6. #26
    Jun 2006
    Orange NSW
    I forgot about this car! Good to see the ball is rolling again, mate!
  7. #27
    Mar 2006
    brisbane
    on like donkey kong.
    Updates!
    Fitted larger rear drums, thanks to the Loon.
    new water pump.
    And probably the best part is I now have no brake linkage! If you also would like to be without this metallic sponge I suggest you contact Matt at Camden GTI. He has done extensive research (ALOT of trial and error)to make solid mk1 brake feel a reality.
    Also tidied up the inlet mani, after porting the inside the outside looked a little scrappy, just need to hit the polishingwheel now.
    Making moves this weekend, expect a picture of a car that looks complete!
  8. #28
    Jun 2007
    Eastern Suburbs Melbourne
    woo for updates.
    How have you found MS so far, and which version are you using?
    i like volkswagens
  9. #29
    Mar 2006
    brisbane
    i am not entirely sure what version it is, probably 2. its in a black case, sold by patatron and if you are savvy to the vortex im sure you know to avoid this guy at all costs. he ripped off a bunch of people and judging by his behavior it wouldn't surprise me if he honestly became a crack head.
    that bs aside, i had it checked and it reportedly functions fine. i bought a blank loom to match and wiring it in has been fairly straight forward. to make things easier i have used the gm water/air sensors that it is calibrated for, i have tapped the water sen into the alloy radiator into a blanking plate.
    i will use a base map from one of the usa guys since my engine is internally standard it should be a fairly driveable match. with the wideband and some logging it should go nicely. i kinda wanted itbs purely for the noise after hearing a 20v 4age
    so to really answer your question, i have little experience! you all will be the first to know as info comes to hand.
    cheers
  10. #30
    Camden, Sydney
    Quote Originally Posted by pepperwhite View Post
    Updates!
    new water pump.
    Thanks for that mate. You are the second to use that setup. I`m 500 road ks into my one and the brakes are fantastic for a Mk1. Feels like something from this century
    Glad to see the car is making progress now mate.
