Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: AEB into a MK1 Cabby - few questions.
    Jul 2007
    Rowville Melbourne
    Dont mean to hi-jack this. Its a very similar motor though, Gav any idea if a BJS motor from a 9N Polo Gti is similar in installation for a Mk1 as a AGU is, or is it like an AEB where certain things have to be changed to make it work? Obviously throttle body would have to be changed, so would a Mk4 Gti ecu and loom work with that engine? Anyone else know?
    Could be another option if AEB is a bit too much work i thought
    -Steve
    Not having done it I don't know the exact details.
    I believe the preference for using the AEB/AGU block is there are cast in bolt holes that will take suitable mounts for the MK1/2. The later 06A block, which IIRC is everything with a 1.8T after the AGU.
    The Polo BJX motor would seem to be a good choice at first glance, transverse is a big plus, the immo can be defeated on the ME7, I already have a Polo ECU done as a loaner.
    The AGU inlet manifold wouldn't match perfectly, the ports are different sizes. You could get a phelonic gasket and use that to fix the problem though.
    I would expect that the AGU peripherals would run a bare Polo engine, again not done it, so can't be 100%.
    Doing this research up front will save you loads of time later on.
    Quote Originally Posted by Shteifen View Post
    -Steve
    May 2011
    Albury, NSW
    Just reviving this thread before I put my AEB on a boat after new years - I've noticed there's one or two APU's for sale in Aus and was wondering if it was worth putting one of these in instead of the AEB - it'd save me 2-3 months of time waiting for the engine to arrive. I like the idea of things just bolting up perfectly - I don't mind having to swap a few engine parts to go from longitudinal to transverse - but having to fabricate mounts and get them certified is a bit off putting.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    PLus point for the APU in my eyes is the ME7 ECU. Defeatable and flashable on the bench. 06A block though so not as good on the mounting front.
