Results 1 to 6 of 6
Thread: Advance and retard - distributor
    Jun 2008
    Guys, someone who owned the car before me (93 Cab mk1) Has blocked off the advance and retard pipe that goes into the distributor with a blanking screw.
    The pipework is connected to all other sources. I have seen this done before.
    Can anyone explain why and whether I should re connect it back up.
    The car seems to pull fine.
    Any advice would be useful.
    1993 MK1 CAB ! Work in Progress........
    Dec 2007
    Somewhere in Melbourne, Victoria
    someone had fun with the vacuum system.
    Try this website:
    http://www.cabby-info.com/images/Eng...gineVacuum.png
    This is for pre-1990 as if Australian built I have found that they are CIS injection, not CIS-E or Digifant.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Jun 2008
    Quote Originally Posted by paulie71 View Post
    Try this website:
    Thanks buddy, doesn't really tell me anything as it is all connected up accept at the dizzy end.
    Reckon I should connect it back up and see what happens ?
    Dec 2007
    Try connecting it up.
    Also not a bad idea to replace the vacuum pipes whilst you are playing there as these are a problem as they age.
    Good luck mate
    Jun 2007
    Eastern Suburbs Melbourne
    as i've learnt with my car. things can seem right and not be.
    SO yea, If you know what you're doing, hook up the advance, see what it does. I'm geussing the distributor has the capabilities of being advanced that is (ie stock..?)
    This probably wont help, but what the hey. Just don't do anything you can't undo!
    i like volkswagens
    Jun 2008
    I didn't hook it up yetserday but delved a little deeper and an external vacumm has been put on the car, which is obviously replacing the original one on the distributor so whilst it runs OK, i think I will let sleeping dogs lie so to speak ! Pommie phrase !
