Results 1 to 7 of 7
Thread: accelerator cable
    Mar 2013
    Act
    accelerator cable
    so i still need to connect the accelerator cable to the carburetor however im stumped on what goes on the end of the cable to stop it slipping through the ferrel. heres a picture to help aswell
    accelerator cable-img_4557[1]-jpg
    the accelerator cable is the red one, just thought i'd point that out
    cheers
    Reid
    But no really, I like to look distinguished when I step out of the car. People are like, "wonder what he does for living."
    I just reply, "your daughter, sir." - some dude on stanceworks
    I had fixed half the broken crap but that just meant it was still halfway inoperable
    Looks like the cable goes through the hole on the throttle arm on the carby - just down and to the left of the center of your picture. Pinch a cable bolt off your bicycle's brakes or gears to go on the end of the cable after you've threaded it through the hole to stop it being pulled out of the hole.
    Mar 2013
    Act
    did everythign you said and it works perfect! new problem, if i accelerate it works but when i lay off the accelerator no fuel goes to the carby, any help is appreciated.
    Is it idling ok?
    The carby has a system where it pumps extra fuel into the engine when you accelerate. It sounds like this bit is working fine but the normal fuel flow into the engine isn't. It could be caused by quite a few things but have a look at the main jets to see if they are clogged.
    Do you have a mechanical fuel pump or electric?
    You should do a Google search on your carby to see how it works and show how it should be assembled. It could have been rebuilt with almost anything done wrong which will affect the way it works.
    Paul
    Mar 2013
    Act
    theres no idling whatsoever, if theres no throttle it just dies. and ill have a look tommorow. no harm done in trying haaha
    cheers paul
    reid
    Sounds like your idle speed needs to be adjusted. When you pull on the accelerator cable it moves a plate on the side of the carby. Somewhere there is a screw that adjusts the plate so it holds the throttle open and therefore increases or decreases the idle speed. You need to turn the screw to speed it up.
    Jan 2006
    Ballarat, Victoria
    I'd look first at the idle cut-off solenoid – make sure that the wire is connected to it
