![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Golf Loon
I think the throttle body will be the same, but the auto and the ac have little solenoid pumps to bump up the idle to keep it running. Worth checking that the kjet systems are exactly the same on both cars.
The auto body has a reed switch which is closed until the trhrottle is at idle. It must nudge the throttle for the auto/AC vehicles using electronic treachery; there are no actuators in the mechanical linkages.
I ended up swapping the units over this am and for whatever reason, after cleaning and adjusting the idle air by-pass, the niggles have dissappeared. Time will tell.
The Jetronic boxes from both vehicles have the same part number so I am assuming they have both the auto and manual functionality resident; just accessed via different I/O's.
Are you gonna wreck the donor car? I want a set of Swaybars from it.
