The one with "G" on it is, and you'll have never seen this coming.. A G grind cam. Probably THE best OEM 8v cam you can get.
The other one, i have no idea.. But it looks to have a lot more duration.. The duration @.050" would be a great deal higher. Probably a better option depending on what you want to do with it..
The G grind will work good with carbs, and pretty much any carb or even duals. The larger cam (depending on the spec ofcourse) should work better with a big carb(s).
It depends on what head you want to put them in though.. No sense running a massive cam and big carbies with a little valve head that's had no port work, etc etc.
Have you used either of them?
