Page 11 of 19 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 187
Thread: '81 U.S Rabbit
  1. #101
    Jan 2010
    Melb Westsideeeee
    Thanks for thst guys, will def look into it.
    So today was very productive. Popped apart the 8v g'box and mated it to the 20v. Took off the timing and started making an engine mount. My buddy Hakan came past and helped me with the mount, measured it all up and starting cutting the 6mm plate while I worked on mounting the inter cooler.
    Got the motor in position, and marked the mount all up. I gave the two bits to my mate and he welded the life out of it. Don't have a pic yet.
    The motor sits in nicely! Next is to replace all the seals, belts, pump etc and paint the bay. Then insert the motor hopefully be next week after I come home from camping, and start all the plumbing.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  2. #102
    You don't hang about do you!
  3. #103
    Jan 2010
    Melb Westsideeeee
    Hahaha Paul, normally I would take it easy but I'm really pushing hard so I can enjoy it before summer ends.
    Pulled the motor out completely today, loom is also gone. Battery tray gone. Will be welding up the mounts just for extra strength hopefully tomorrow.
    Today's progress, inter cooler as far left possible and the rad as far left. A lot of mucking around to get them to sit nicely, but it's done.
    Welded nuts to the rad support as new mounts. Also cut out the rest of the metal at the front apron to enlarge the holes for air flow. I'm really liking the cooler hahahaha
    Mount fully fabbed up and welded.
    That's it for today, I'm dead and I've got work in the morning! Enjoy
  4. #104
    Jan 2012
    St Albans, Victoria
    Good stuff George can't wait.
  5. #105
    Mar 2011
    Bunvegas, Western Australia
    Yessssssss ��
    1976 VW Golf "Swallowtail" - Rallye Red (long term resto)
    2009 Pirelli GTI - Stg3 killer
    2009 R36 Passat - Daily baller
    You take corners on three wheels, and V8's can't catch you.
  6. #106
    Jan 2010
    Melb Westsideeeee
    So yesterday I bought a 8mm plate, and made the spacer required for the 16v bearing. Oh and thst came in too! Thanks bearing wholesalers. I've prepped the bay aswell with a wire brush, not going for a show finish so I couldn't be bothered taking 2 years to sand the bay by hand. Have also cut and relocated the fuel pipes as per new motor.
    Attempted to make a stud for the tensioner, but I'm a noob with a tap and die set so i ****ed that up haha. But will make one eventually.
    Have cleaned everything up and just through a mist/light coat one. More updates to come
    Pipes
  7. #107
    May 2011
    Albury, NSW
    dude...stop it...
    where abouts have you put the fuel pipes now then?
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  8. #108
    Jan 2010
    Melb Westsideeeee
    Final coat is about to go on, looks really nice and neat. Happy with the result just hope it holds up on the long run. I used Septonw chassis black for those who were curious, as I was too lazy to primer.
    The fuel lines are going to be left as they are dude, just like the pic above. I will be running rubber hoses from there on.
  9. #109
    Jul 2011
    Good stuff dude! What kind of finish did the chassis paint leave?
  10. #110
    Jan 2010
    Melb Westsideeeee
    Marcus, I'm yet to check out the final finish but Id strongly imagine a flat/satin.
