Page 68 of 80 FirstFirst ... 1858666768697078 ... LastLast
Results 671 to 680 of 793
Thread: 78 2-Door Build Thread
  1. #671
    Perth. WA
    I have the correct KR water tube here Michael, I think there still available from VW classic parts. part number is 027 121 065K
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  2. #672
    Mar 2009
    Quote Originally Posted by roccodingo View Post
    hey grant, that's the same one as i'm using - probably just unclear in my photo, taken on the mobile!
    78 2-door 1.8 KR 16v - twin dellorto's
  3. #673
    Perth. WA
    cool, that'll be fine.
    Pix 4 clix anyway
    Heater valve and hose 12 go to heater inside the car, make sure you have hose 5 connecting head end port to coolant pipe.
    Cheers,
    Grant
    Cheers,
    Grant...
  4. #674
    Mar 2009
    spending most of my time lately trying to find a place to mount the computer and module. bit of a bulky item and don't really wan't to cut a bunch of holes in the newly painted engine bay. i have decided to mount this up under the rain tray, mostly out of the weather but still with the potential of a bit of rain getting near the computer i have made up a protective case out of perspex (still haven't finished off but this is the rough idea). pretty happy with the way it came up and basically by applying heat with as heat gun you can bend/mould this however you want (pics below). also, my girlfriend's dad has made me a hose adapter on the lathe for the crank case breather hose, so i can run a 19mm hose to fit the catch can. thoughts? cheers.
  5. #675
    Mar 2009
    hey guys, haven't really updated on here for a while now. but i have essentially finished the conversion for now, obviously with a few teething issues but overall really happy with the way it has turned out so far!
    I have uploaded a video below, haven't been able to drive on the road as rego ran out on Friday! (perfect timing) will get some better photos once I get it out of the garage and give it a wash etc etc
    Cheers!
  6. #676
    Woohoo !!!!
    Bet you feel great.
    Now I'm jealous.........Makes me wish I'd never sold mine, even with all the rust it had.
  7. #677
    Mar 2009
    bonnet shut and now won't open...latch is stuck...this is just great
  8. #678
    Aug 2006
    Melbourne VIC
    Stick a screw driver threw the grille.
  9. #679
    Nov 2010
    Melbourne - SE
    Quote Originally Posted by Water Boy View Post
    Stick a screw driver through the grille.
    come on woody you know better than that
  10. #680
    Boronia VIC
    The bonnet safety catch might have grabbed the top of your radiator.
    I removed the hook from my white car because of this. I have other bonnet restraints so it wasn't a problem.
    You might need to bend up a coathanger or someting to pull the hook back enough to get the bonnet free again.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
