Page 66 of 80 FirstFirst ... 1656646566676876 ... LastLast
Results 651 to 660 of 793
Thread: 78 2-Door Build Thread
  1. #651
    Jan 2012
    St Albans, Victoria
    Pm'ed you
  2. #652
    Aug 2006
    Melbourne VIC
    16 valves and 2 cams?
  3. #653
    Mar 2009
    and the build continues...
    8v now out of the car and getting the bay for a DIY paint job, hopefully it turns out OK!
    picking up the 16v in two weeks.
    also, does anybody know where i can look/buy twin delortto manifold to suit KR 16v?
    cheers.
    78 2-door 1.8 KR 16v - twin dellorto's
  4. #654
    Aug 2006
    Melbourne VIC
    These guys are awsome. Tim has one of their 8v cross flow manifolds and it looks the business.
    Rowland Manifolds Cape Town South Africa
  5. #655
    Mar 2009
    Quote Originally Posted by Water Boy View Post
    cheers woody, emailed the blokes and they have the one I need, will order shortly.
    also is it possible to use 8v headers on a 16v if i change the flange? ie are the pipe diameters and spacing the same? don't have the engine in here to check myself yet.
    finally, been reading up on the net in regards to choosing a radiator. the standard mk1 radiator probably won't fit due to clearance, seen a number of mk1 16v with side drafts running small sandwich style radiators with a really thick core, any opinions in to which would be best or what works well? thanks
  6. #656
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by dubmc View Post
    Pretty sure the space on a 8v is II II where as the 16v is I I I I (I being the exhuast port) so no your extractors will not work. And check out Alex G's radiator. You can use I think a Honda civic which is thick and not as wide. Or have something made up!
  7. #657
    Mar 2009
  8. #658
    Jan 2006
    Nice Has the carby manifold arrived?
  9. #659
    Mar 2009
  10. #660
    looks great dude!
