Originally Posted by
abreut
That is strange. Unless the head seized? Maybe take the cam out, inspect the caps and make sure all the valves seat.
Yah. First thing take off the cam, inspect all the journals for scoring. Low oil pressure will usually result in scoring in the can journals. If it got bad, the cam may have siezed. In my experience this would be the first to go with low/no oil pressure. Generally you will have trouble killing a golf bottom end without oil pressure before you start to really muck up the head. The alloy can journals get bad fast.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
