Page 54 of 80 FirstFirst ... 444525354555664 ... LastLast
Results 531 to 540 of 793
Thread: 78 2-Door Build Thread
  1. #531
    Mar 2009
    Quote Originally Posted by ffoff View Post
    it wouldnt be easier and or cheaper to just buy a new box?
    yeah it may well be, i'll look into during the week and see what is the best option long term, i will also upgrade the clutch while i'm there...
    78 2-door 1.8 KR 16v - twin dellorto's
  2. #532
    Aug 2009
    ACT
    see what happens, I've got an audi 1.9l and 5 speed box from my parts car you can use if need be.
  3. #533
    Jul 2005
    Newcastle, NSW
    What a shame mate. But you'll end up in a better place once you've got through this and out the other side.
    And probably a whole heap wiser!
  4. #534
    Boronia VIC
    You could change to diff to one that takes circlips or use the experience to justify putting in an LSD.
    If you're not fussed about ratios the MK3 boxes are cheap.
    I'm puzzled as to why you've got a bolt retaining the flange all the 5 speeds I've seen have circlips.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  5. #535
    Mar 2009
    yeah it's an 020 5-speed...i haven't seen any other MK1 gearboxes, but yeah this one definately has the centre allen key to hold the diff flange one...the previous owner had modified it, not myself and as i've said put one of those crappy friction kits in...i would obviously put a poper LSD in, but student wages don't allow for it.
    however, i can feel the groove on the shaft where a circlip would go...are you suggesting that this would be enough to hold the whole flange on? would it be worth a try?
    if i do need to replace the box i will look for a short ratio box...recommendatios? as i will be looking to increase engine capacity in the future as well.
    thanks!
  6. #536
    Boronia VIC
    Definitely worth a try, normally that threaded hole has nothing in it, it's only used to install the flanges. Take a look at this page.
    020 Flange
    The circlip is all that's required.
    As to close ratio gear boxes, they're hard to find.
    There's three different diff ratios in the close ratio boxes, 3.94, 3.89 and 3.67
    3.94 is what I use, it's the lowest of the stock ratios and gives you about 200Km/h at redline in 5th. Punchy out of the corners.
    3.67 is higher and more economical on the street.
    Close ratio gear box codes and ratios are
    FM FD FK
    3.45, 2.12, 1.44, 1.13, 0.91 FDR 3.89
    4K
    3.45, 2.12, 1.44, 1.13, 0.89 FDR 3.94
    4Y 9A ACD AEN
    3.45, 2.12, 1.44, 1.13, 0.89 FDR 3.67
    7G
    3.45, 2.12, 1.44, 1.13, 0.91 FDR 3.65
    2H
    3.45, 2.12, 1.44, 1.13, 0.91 FDR 3.94
    AGB 2Y
    3.45, 2.12, 1.44, 1.13, 0.91 FDR 3.67
    7? MK1 Caddy
    12 Amarok
  7. #537
    Mar 2009
    020 Flange
    FM FD FK
    4K
    4Y 9A ACD AEN
    7G
    2H
    AGB 2Y
    thanks pete, extremely useful information! i'll investigate further but i can see what your saying! much appreciated.
  8. #538
    Mar 2009
    so a massive thanks to pete jones...absolute guru and saved me the extreme hassle of taking out the gearbox and potentially outlaying a lot of money...
    as suggested by pete there is not meant to be a bolt into the stub-axle. obviously a previous (non-vw) workshop and done a dody and just used a bolt instead of the factory set-up...
    this afternoon i removed the crappy set-up and prepared it for the factory washer and circlip which should be arriving friday!
    i also fabricated a home-made flange installation device as it's the only way to do it properly due to the thickness of the spring behind the flange!
    anyway was happy with the way the tool came up (no bad for someone who works in media ahah and should have the car back on the road this weekend.
    pete i owe you a beer.
  9. #539
    Jan 2010
    North Shore
    I'm guessing you were able to get the bolt out from inside?
  10. #540
    Mar 2009
    Quote Originally Posted by Rob Burns View Post
    there didn't seem to be any in there, to be honest I think the bolt had been cut in half very roughly with a grinder...I used that tool to repair (can't remember the name right now) the thread to a respectable state, enough to get the threaded rod to bite...cheers rob
