so this is where i'm at this afternoon...noticed the passenger side drive shaft had some play and on closer inspection realised the flange was coming away from the diff...when i removed the inner cv joint the centre flange allen key was completely loose, which was the reason for the play and oil leak from round the flange.
now it's a matter of getting the flange back in against the spring load in the diff and tighting the allen key. any advice as to how best over come the spring loaded pressure? also, would it be worth while using some lock tight on the centre allen key? advice appreciated! thanks!...
