Results 1 to 10 of 793
Thread: 78 2-Door Build Thread
    Mar 2009
    have been brainstorming some upgrades to the golf...i'm going to leave it as in for now but will change the cam to give it more low end grunt and get it tuned properly as it's running pretty rich..
    my aim in the next 6 months is to firstly save up lol and then swap a 2L bottom end into it which I have that has been built with upgraded pistons/rods and is all balanced etc..I will then look at getting a big valve 1.8 head and doing all the bits to it...valves, springs, cam etc etc...this same setup in a 75 passat wagon was doing 15 or 16's at the 1/4 mile so it should go great guns in the mk1...
    i have now have a terminal disease known as "need more power"
    78 2-door 1.8 KR 16v - twin dellorto's
    Jun 2007
    Eastern Suburbs Melbourne
    Hahah, that's fantastic, I love it!
    i like volkswagens
    Mar 2009
    was told today never to run 98 Ron in carburettor engines...
    was told this was the reason for my fuel consumption issues and fouling of the plugs...
    i think its more so to do with the mixtures and timing which probably need to be checked after it copped a hiding a wakefield...
    any thought on this? is 95 Ron the 'best' option?
    Aug 2006
    Melbourne VIC
    Ummmmm im pretty sure most people with a "warm engine" would run a higher octane fuel.
    A good tune will have you running the best. Which should have consumption spot on and power at maximum.
    Maybe the car is over jetted causing plugs to foul and excessive fuel use.
    Jun 2007
    I can't see how running the best quality commericially available fuel (ie 9 is a bad things. Should give you a better bang cleaner burner. etc, might also be able to run a touch more timing.
    I echo woody's sentiments though. Spend the cash, and get them tuned up properly. Take them to a place with a dyno, and a couple old alfas hanging about (They have twin DCOE's as standard ) That should see it run a bit smooth, get better economy (if you're running too rich and fouling plugs atm) and hopefully get a few more neddies though.
    You may want to look at other short term goals too, ie cam, electronic ignition and stuff. No point getting it tuned, only to change cam a month later, if you know what I mean?
    i like volkswagens
    Mar 2009
    yeah of course, im changing the cam and lifters at the begining of next week and were going spend a bit of time giving it a good tune when we do that...
    i couldnt see how 98 ron would make such a difference, and as you said it gives you longer strokes without the chance of pinging/unburt fuel...
    while we are on the topic, does anybody know of a quality tuning place in syd who would be willing and have the know how to fiddle with mixtures?
    Jun 2006
    Orange NSW
    Quote Originally Posted by dubmc View Post
    Told not to run 98 ron? That's complete bull****.
    If you are fouling plugs, the carbs are over jetted or the plugs are too cold. If you are running standard heat range plugs, it's just simply too rich. Stick 4 litres of metho in the tank next time you fill it up, or try E10 (same thing). If it runs better, you're too rich.
    Ethanol needs a richer AFR, so if you use an ethanol blend with the same jetting the AFR will actually be leaner.
    I used to run E10 premium in my Mk1 1.7 11:1 comp, G grind, ported, 44 IDF weber engine religiously. And i'll be doing the same for my 16v. Heaps better stuff.
    Jan 2010
    Melb Westsideeeee
    So wait, if your engine is running a bit/lot richer, you'd advise to use e-10 preeny?
    Hmm that explains why theres less smoke when i use e-10.
    Sorry to hi-jack thread, but i was about to open a thread on petrol smell, however seeing as its in discusion.
    What can cause excessive petrol smell inside the car? Could that be due to over fueling?
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Jun 2007
    Possibly George, could also be due to fumes from the engine bay leaking into the cabin, (through the front) or exhaust getting drawn into the cabin, through under the tailgate. Check your boot seal mate, as well as engine bay seal (rain tray rubber). If you've got a leak, and you're overfuelling, well yea, you'll smell it in the cain pretty clearly.
    i like volkswagens
    Jan 2010
    Melb Westsideeeee
    Hahaha will do mate. I know i dont have a rain tray rubber, and my boot seal isnt 100%
    I get outta the car high all the time .. feel like snoop dog whenever i hop out lol
