I know exactly where a new mk2 water pump is. I left one down at Camden GTI.prolly can use your original pulley.
Also, don't mk3s run serpentine belts and golf 1/2 run V belts?
yeah i bought a mk3 pump...i just assumed it was going to be that because it was on the mk3 1.8 and they look so similar, but i think the previous owner put the mk1 pump on instead...yeah i think i will try and source an earlier pump (mk1/mk2)...hope these are easy to come by...would save me a lot of trouble.
78 2-door 1.8 KR 16v - twin dellorto's
87' MK2 GTI
13' MK7 TDI
Should replace the o-ring gasket while your at it.
Audi S3 8L - Stroker GTX3582 700bhp+
Golf GTI 1980
Golf GLS 1979
www.facebook.com/etunersmotorsportau
Not on the waterpump. They are all v belts.
THe Mk3 ones have a different offsett and bolt spacing to the Mk1 ones.
There are untold pulleys available with different offsets.
If you measure up what you need, pulleywise, and give us specs, I`m happy to look for one for you.
problem solved...bought a complete new original mk1 water pump/housing & thermostat/seals
so now the motor has had a top end vrs kit and bottom end has all new gaskets/rings and complete new water pump...fingers crossed its all worth it later on when i don't have little issues popping up...
got the engine basically ready to for next weekend...just have to finish up a few things...connect hoses etc and find a different pulley...other than that its all looking good for this weekend
That looks bloody awesome dude!![]()
