Page 13 of 80 FirstFirst ... 311121314152363 ... LastLast
Results 121 to 130 of 793
Thread: 78 2-Door Build Thread
  1. #121
    Mar 2009
    yeah i bought a mk3 pump...i just assumed it was going to be that because it was on the mk3 1.8 and they look so similar, but i think the previous owner put the mk1 pump on instead...yeah i think i will try and source an earlier pump (mk1/mk2)...hope these are easy to come by...would save me a lot of trouble.
    78 2-door 1.8 KR 16v - twin dellorto's
  2. #122
    Sep 2007
    I know exactly where a new mk2 water pump is. I left one down at Camden GTI. prolly can use your original pulley.
    Also, don't mk3s run serpentine belts and golf 1/2 run V belts?
    87' MK2 GTI
    13' MK7 TDI
  3. #123
    Mar 2009
    Quote Originally Posted by jayjay View Post
    thanks man, any chance i can get my hands on it before the weekend?
    not sure to be honest, i have never dealt with water pumps before, sort of learning it all as i go...
  4. #124
    Should replace the o-ring gasket while your at it.
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  5. #125
    Camden, Sydney
    Not on the waterpump. They are all v belts.
    THe Mk3 ones have a different offsett and bolt spacing to the Mk1 ones.
    There are untold pulleys available with different offsets.
    If you measure up what you need, pulleywise, and give us specs, I`m happy to look for one for you.
  6. #126
    Mar 2009
    Quote Originally Posted by 16v_kid View Post
    yeah i'm replacing most of the gaskets on the bottom end..pulleys...coolant flange etc
    thanks matt, will get back to with some specs.
  7. #127
    Mar 2009
    problem solved...bought a complete new original mk1 water pump/housing & thermostat/seals
    so now the motor has had a top end vrs kit and bottom end has all new gaskets/rings and complete new water pump...fingers crossed its all worth it later on when i don't have little issues popping up...
  8. #128
    Mar 2009
    got the engine basically ready to for next weekend...just have to finish up a few things...connect hoses etc and find a different pulley...other than that its all looking good for this weekend
  9. #129
    Mar 2009
  10. #130
    Aug 2009
    That looks bloody awesome dude!
