Page 12 of 80 FirstFirst ... 210111213142262 ... LastLast
Results 111 to 120 of 793
Thread: 78 2-Door Build Thread
  1. #111
    Aug 2009
    Motor should go very nicely with that top-end! I'm jealous.
  2. #112
    Jun 2007
    Eastern Suburbs Melbourne
    wow that dash looks grouse!
    well worth the wait!
    and woot for cruising in the mk 1's!
    i like volkswagens
  3. #113
    Mar 2009
    78 2-door 1.8 KR 16v - twin dellorto's
  4. #114
    Mar 2009
    so the top end is all done, still have to tidy up the bottom end...i want to give the block a clean and a paint as best i can...also considering getting a new water pump as it looks pretty well used?...
    one of the threads in the gearbox holes is shot and the bolt doesn't bite so i will have to get it re-threaded...
  5. #115
    Nice engine
    What adjustable timing gear you got there? Looks just like ours.
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  6. #116
    Aug 2009
    Simple goodness.
  7. #117
    Sep 2007
    looks good mate! keep it going.
    is that one of the old school techtonics tuning adjustable cam gears?
    how are you going to run the ignition advance?
    87' MK2 GTI
    13' MK7 TDI
  8. #118
    Oakleigh VIC
    That's what this forum need, More carbys!
    Lookin' good!
    Pages 28 and 29 of my wreck to race thread show how I made up a throttle cable which might be of assistance to you.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  9. #119
    Mar 2009
    bought new water pump today, thought it would be a simple swap...but the internal diameter of the original pulley wheel is much larger than the fitting on the new pump so the wheel/pully doesn't line up with the holes, nor do the bolts/washers...anybody got any ideas?
    i will probably ring vw tomorrow and see if i get a later model one and see if it's any different....
  10. #120
    Oakleigh VIC
    Sounds like you got a late model pump. I think (but you'll need to check) that a MK2 pulley might be what's required.
    7? MK1 Caddy
    12 Amarok
