Thanks for the tip. Will give it a go.
try some vinegar on those paint spots circular generous application(cheap rust converter) leave it on a few hrs
white vinegar if you have it
if no go use a rust remover same appl. it worked on my white datto through all the cracks it had.
german - english translations esp vw documents!!
Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Change of plans (temporarily).
I found an original MK2 GTi K-jet 1800 motor (112 hp Euro version) and it would be un-Australian not to put it into a MK1. It's from Alex G's brown 1985 MK2 and it came with Alex's gearbox which has been pinned so should be a good combination for my car.
The plan is to use the plumbing and wiring (including the fusebox) from my MK2 to change it to digi so it should be an easy swap. Plus having the wiring done to CE2 specs makes it easier to do the 16v transplant when I get that motor rebuilt.
It's ironic that my MK2 donor car is the car that Alex G used as his daily while building his awesome MK1.
Who knows what I can modify (and keep the car street legal) for doing some serious track work?
I want to build the Golf for racing at Wakefield Park but still eligable for historic rego.
Mate just joined the forum and I'm based in Goulburn. Own a MKV R32. Ever what a catch up let me know.
We need to organise a local meet sometime.
Definitely need to organise a meet up for Canberra region...
Other than you, I haven’t seen them in years.
Another Question is, who will have their car registered first... you or me?
'90 Mk I Cabriolet 1.8L - My toy... err... Daily driver...- Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
'99 Mk IV Bora V5<-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
'05 Volvo T5 S60 - 2.5L Turbo AWDReplaced with '09 Ford LV Focus Sedan <-- Used by the kids
'07 Eos 2.0 TFSI - Project Eos...
Definitely you. I've got a few other cars to get back on the road first.
