Page 42 of 80 FirstFirst ... 32404142434452 ... LastLast
Results 411 to 420 of 793
Thread: 78 2-Door Build Thread
  1. #411
    Mar 2009
    That style of harness doesn't have an expiry date. Scrutineers will check condition and ADR compliance on that one.
    Generally speaking anything with the passenger car type of buckle doesn't expire.
    When the seat goes in make sure it doesn't rattle. Even with brand new nylon guides on the back feet there can be some slop.
    In my MK1 I adjust the seat position wise and then use strips of aluminium the width of the rail to shim the nylon guides and get everything nice and tight.
    The shims just slide in under the runners and I bend them up on either side to keep them in place.
    You can shim out any slop in the front mount too by sliding a piece of aluminium in on top of the rail. Securing that is a little harder, I bent a tab down off it and used the M6 bolt at the front to keep it there.
    I made that seat base back in 1998 http://www.vwwatercooled.org.au/f55/...-13857-11.html
    It's fair to say I somewhat over-engineered it. It's a bit heavier than it needs to be although the whole seat and base still only weighs 12kg.
    I didn't have a MIG welder back then, all those welds were done the old fashioned way with oxy-acetylene.
    Good to see it getting used again. All the best at the Nationals!
    thanks Pete, I was actually looking at it yesterday and thinking how nicely put together it was. Once I put it in, I will have a look how it sits in terms of height and rigidity and maybe look at making up those shims for the tracks and adjusting the height with some spaces...
    so your saying I can't use the harness?...would I be wasting my time to install it? or if it is in good condition and ADR compliant I will be ok?
    Thanks.
    78 2-door 1.8 KR 16v - twin dellorto's
  2. #412
    Boronia VIC
    Harness is fine. That style is good for club level events. Should always pass scurineering as there's no expiry on it.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  3. #413
    Mar 2009
    cool thanks...
    went to put the seat in today, i can see it will all work but the courier must of handled it roughly because one of the slides has been bent and plastic glide broken, so I need to source a new glide, I almost straightened out the slide/plate back to how it was but will make it a bit better tomorrow...
  4. #414
    Boronia VIC
    Gary Collis at Wolfsburg Automotive has brand new glides for those. He had them at the swap meet today. If I've had realised I would have picked some up for you. He's got the front ones too.
    You can always pull one of the glides off your existing seat at a pinch.
    Pete
    7? MK1 Caddy
    12 Amarok
  5. #415
    Mar 2009
    so after 3 weeks.............
    REGO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (BL.23.BU)
    can I get a f*ck yeah!
    heading to suspension place now to set up my camber and wheel alignment
  6. #416
    Aug 2009
    Sick dude. Feels good huh!
    Go for a hard fang after the alignment?
  7. #417
    Aug 2006
    Melbourne VIC
    Awsome cant wait to see this Saturday morning at Wakefeild.
    Keep it in one piece between now and the weekend!
  8. #418
    Jan 2008
    Strathfield,Sydney
    come pick me up for a fang tonight! i should be able to give you my glides by wednesday
    76 Scirocco
  9. #419
    Mar 2009
    Quote Originally Posted by dom123 View Post
    I will braz, I have to go to uni to submit an assignment at 8 but I'm free after that, I'll give you a buzz
    will be good at Natio's this weekend finally we can go to a show together in our cars.
  10. #420
    Sep 2009
    Chillaxing in Tas
    **** YEAH!!!!! <insert manly chest bump>
    <space for rent>
