Page 16 of 19 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 185
Thread: 76 Sweetheart
  1. #151
    Feb 2013
    Melbourne SE
    So the gearbox rebuild has been keeping me busy of the late. The internals look very good overall, only issue has been a broken synchromesh and a decaged bearing that will need to be replaced.
    To those who know 020s, this is the gearbox code that is getting a spruce up...
  2. #152
    Jul 2011
    Aw yissss!!
  3. #153
    Feb 2013
    Melbourne SE
    Yay! Cracked synchro hub discovered after reassembly... Time to press it off again and source a replacement. Lucky I have 3 unusable 020s sitting around
  4. #154
    Feb 2013
    Melbourne SE
    So.
    Here is the latest with the gearbox rebuild. Me being the novice that I am, I accidentally forgot to put the thrust washer under first gear, and as a result, 1st gear was floating when I assembled the output shaft. This lead me to believe that I had not pressed the 1st/2nd sync hub all the way on, so I kept pressing... and pressing... and pressing... until finally...
    There goes the output shaft through the bellhousing. 76 Sweetheart
    Lucky I have a spare case due to completely destroying the selector shaft cover on disassembly. So the rebuild started again, again.
    Some pictures of second time around
    And the home-made press to close the main case
    And the finishing touches
    Complete
    I wad considering painting it body colour for ultimate baller spec, but reading that painted gearboxes can cause oil temps to peak 10 degrees higher than an unpainted gearbox, I decided to play it safe.
    Finally a summary:
    Code: AWY
    Ratios: 3.45 1.94 1.44 1.13 0.89
    Ring/pinion: 3.94:1
    Rebuilt with:
    - All new synchromesh on every gear
    - New pinion bearing
    - Diff bolt kit
    - Late style 3rd/4th sync hub
    - All new seals, gaskets and circlips
    - 90mm CV flanges
    Now just for the install, which means engine out for the 3rd time this year... Perks of having a mk1 daily driver. I've also got another small project in the works for the sweetheart, which should be a little bit of fun.
    Stay tuned.
  5. #155
    Jul 2011
    Takes a big set of stones to play around with the big toys!!!
  6. #156
    Jan 2012
    St Albans, Victoria
    This must make you a gearbox specialist right? Good work Jordan.
  7. #157
    Feb 2013
    Melbourne SE
    Some quick eye candy from the Brokegang meet the other night
    Quote Originally Posted by Petska84 View Post
    Specialist, no. Enthusiast, yes. I'll consider myself a specialist if she moves under her own power
  8. #158
    Aug 2016
    Sunbury, Melbourne
    Good seeing you at the meet man! Even if it was only a hi five on my way out haha
    Car looked mad
  9. #159
    Jan 2010
    Melb Westsideeeee
    Was the meet any good dude?
    Good work on the box, I'm always really scared to do anything gearbox related.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  10. #160
    Feb 2013
    Melbourne SE
    Fun little weekend at Winton in the Sweetheart. Rebuilt gearbox installed and some semi-slicks equals a world of fun on the track. A whole new dose of issues has surfaced, so engine out again is on the cards.
    Enjoy the music of those twin Dellortos
