Page 4 of 19 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 185
Thread: 76 Sweetheart
  1. #31
    Feb 2013
    Melbourne SE
    So am I right to just cut it out? Or should I at least relocate it
  2. #32
    Feb 2013
    Melbourne SE
    So I wised up...
    Any guesses as to what's going through here...
    Big weekend ahead I think. Stay tuned
  3. #33
    Let me guess, hot water plumbing for the rear mounted washing machine?
    Sorry, couldn't resist.
    Radiator looks like it was made for the MK1.
  4. #34
    Feb 2013
    Melbourne SE
    If only that was true. Much more interesting than what it's actually for. Got to keep those wires weather tight though
  5. #35
    Feb 2013
    Melbourne SE
    Here's the plan for the weekend in a few words.
    Fix this
    And run it through there
    How come no one told me how difficult this was going to be...
  6. #36
    Feb 2013
    Melbourne SE
    Before...
    After...
    239mm gti discs and calipers just became 280mm g60 discs with calibra v6 calipers.
    I'll let y'all know how they perform once the car is in its feet again
  7. #37
    Are you using adapter brackets to fit the calipers or do they bolt to the same place the old calipers bolted to? Pix please.
  8. #38
    Feb 2013
    Melbourne SE
    No adaptors needed! Opels and Vauxhalls used the same caliper bolt spacing and disc diameters as vw on their front wheel drive cars. Its possible to get Opel/Vauxhall calipers to suit both a 256mm and 280mm big brake upgrade for the mk1, just need the correct vw 4 stud discs (g60 in my case).
    Only thing you need to get them to work are shoulder bolts to step the thread back down to a m10, but still hold firm in the 12mm holes on the calipers. I'll make sure I take lots of photos and part numbers for those who are interested.
  9. #39
    Aug 2006
    Melbourne VIC
    Nice upgrade!
  10. #40
    Feb 2013
    Melbourne SE
    So here's the recap from the weekend's work. Finished off the wiring loom gents, so here are some photos, even though it couldn't be a more boring topic...
    Colour coded connections for further simplicity
    Off with the dash for some more wiring upgrades
    It's seen better days
    But I have a plastic dash in fair condition which will be replacing it
    A little bondo and it's ready for the rest of the the next part of the restoration
    Add in some new gauges and some oem goodness
    Additionally to the work I've done I got some photos of the brakes that are going on for those who are interested
    Part numbers
    Old bolts and new shoulder bolts for the mk1 hubs
    Only issue is the brake pads overhang the inside of the friction surface, meaning it'll be a prick to remove once it starts wearing in
    Can't decide what to do next... Get it running and driving, or strip it down again for a paint job? I'm open to suggestions
    Much love
