How good is winton as a track? I love it man. Carbs sounds awesome too
What issues arose?
When I used to race my Honda I was on 1.44 and you look pretty quick so I'd say your time would have been much better than 1.51 with a proper timer!
What issues arose?
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
Just some alternator issues that prevented me from getting the whole way home. Rear main seal is leaking (I suspect). I'm going to replace both front wheel bearings and ball joints. They're all original 1976 hardware still
Good to see you're using the correct MK1 high tech lateral gravitational measuring device and it's mounted properly - hanging from the rearview mirror.
Car sounds good.
Paul
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Sounds good is an understatement. This thing sounds incredible in the flesh... spot on job with the track day! I really need to get **** together for the next track day haha
Well well well, it's all fun and games until someone cracks a strut tower![]()
Never seen that before. Might be time for an upper stress bar.
You going to reinforce it or just weld it up?
The plan is to weld the crack and reinforce with a strut brace. Hopefully that will be sufficient to prevent it happening again
Ouuuuch. Suspension is too stiff by the looks of it! Could it be the lack of washer?
