Aw yissss!!
So the gearbox rebuild has been keeping me busy of the late. The internals look very good overall, only issue has been a broken synchromesh and a decaged bearing that will need to be replaced.
To those who know 020s, this is the gearbox code that is getting a spruce up...
Aw yissss!!
Yay! Cracked synchro hub discovered after reassembly... Time to press it off again and source a replacement. Lucky I have 3 unusable 020s sitting around
So.
Here is the latest with the gearbox rebuild. Me being the novice that I am, I accidentally forgot to put the thrust washer under first gear, and as a result, 1st gear was floating when I assembled the output shaft. This lead me to believe that I had not pressed the 1st/2nd sync hub all the way on, so I kept pressing... and pressing... and pressing... until finally...
There goes the output shaft through the bellhousing.
Lucky I have a spare case due to completely destroying the selector shaft cover on disassembly. So the rebuild started again, again.
Some pictures of second time around
And the home-made press to close the main case
And the finishing touches
Complete
I wad considering painting it body colour for ultimate baller spec, but reading that painted gearboxes can cause oil temps to peak 10 degrees higher than an unpainted gearbox, I decided to play it safe.
Finally a summary:
Code: AWY
Ratios: 3.45 1.94 1.44 1.13 0.89
Ring/pinion: 3.94:1
Rebuilt with:
- All new synchromesh on every gear
- New pinion bearing
- Diff bolt kit
- Late style 3rd/4th sync hub
- All new seals, gaskets and circlips
- 90mm CV flanges
Now just for the install, which means engine out for the 3rd time this year... Perks of having a mk1 daily driver. I've also got another small project in the works for the sweetheart, which should be a little bit of fun.
Stay tuned.
Takes a big set of stones to play around with the big toys!!!
This must make you a gearbox specialist right? Good work Jordan.
Good seeing you at the meet man! Even if it was only a hi five on my way out haha
Car looked mad![]()
Was the meet any good dude?
Good work on the box, I'm always really scared to do anything gearbox related.
- Brown U.S import 81 cabby
- 88 Honda crx b18cr
Fun little weekend at Winton in the Sweetheart. Rebuilt gearbox installed and some semi-slicks equals a world of fun on the track. A whole new dose of issues has surfaced, so engine out again is on the cards.
Enjoy the music of those twin Dellortos
