But no really, I like to look distinguished when I step out of the car. People are like, "wonder what he does for living."
I just reply, "your daughter, sir." - some dude on stanceworks
I had fixed half the broken crap but that just meant it was still halfway inoperable
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Hahahaha, it takes big ones to do that trip in a mk1. Hang on you forgot something George!! Didn't it also have 3 spark plugs fitted on the way back?
So good news. All the glass (except windscreen) is in the car. Such a PITA but with the much appreciated help from Marc, we got it done. Just need to get my rear beam back from the powder coaters (hopefully today) and the car can be put back on her own feet for the first time in 4 months.
Keen as a bean
Hi Jord,
Read your thread and car looks great..
Lots of work but its the best way to learn.
Your 2 door reminds me of your grand mothers Golf from many years ago..
Give me a yell if you need any advice etc.
30 years of playing with VWs may be of some use to you.
Currently in the middle of converting my '67 Kombi to VR6 power and hoping to have it at DOVW
this year..
Cheers Tony Anstee
Update. Engine fired for the first time today which was mega cool!!! Sounds so so SO good!
Just a few quick questions.
When I first started the car, there was fuel leaking out the front of the carb (the trumpet side). Initially it was only on the carb feeding pistons 1 and 2 so I took the cap off and fiddle with the floats and needle valve. But the same thing happened on the other carb the next time around. Could this be because I was running on the choke for quite a while? (mainly because I can't start it with the accelerator circuit yet). Has anyone set up twin dellortos on a 1600 or 1800 before that can help me out?
Second thing, my coolant temp gauge hits the red as soon as I turn the ignition on. I've read this can be because it is shorting out across the temperature sensor?? But even completely unplugged it still does the same thing. Might have to check through my connections in the wire tuck to make sure it's not shorting out. What's the voltage meant to read at the sensor when the engine is cold and when it's hot?
Lastly, my radiator (the barina one) isn't getting hot when the engine is running. The "top" hose (coming from the head but is actually going to the lower spout on the radiator ) is hot but the "bottom" hose (again, is really the upper hose but goes to the thermostat housing) is still cold. I'm fairly sure that the thermostat would've opened at that temperature (and it's brand new) so my only conclusion is that there is an airlock as the water exits the radiator. This is because the upper radiator outlet points upwards, meaning I need to put an elbow in the hose, possibly catching air as it exits the radiator. Anyway, I put a small bleed screw in at this point so hopefully next time around it works a little better.
The hose in question can be seen on the far side of the carbs in this pic.
Advice on any of these issues will be great appreciated!
