put a later model 5 speed in the car, probably out of mk3 with the 100 mm cuplinks are the mk1 shafts compatable with the later gear boxes?
i'm asking this because i cracked the bearing cage on the inner cv which means that the outer section of the cv joint might not be in line with the inner section.
i have a feeling the distance between the the two couplinks on the later model is wider than the earlier model gear boxes
The cups are all the same size. Distance is the same.
